Originally posted by clackers Why are the Mark Kitaoka results seemingly at odds with Toni's, ladies and gents?
Perhaps Toni999 used the MBX500 at relatively low power settings.
The Priolite "HotSync" technology does not provide "HSS" lighting, but rather is a "HyperSync" approach in which advanced syncing is used but the strobe does not produce a burst of many pulses to approximate a continuous light source, but only produces one long pulse.
If the MBX500 uses IGBT technology then lower power settings will produce shorter flash pulses and hence lead to more pronounced dark bands towards the top and bottom of the frame.
@Toni999: Could you repeat your experiment at different power level settings?
Does the manual say something about flash durations at various power levels?
P.S.: In some of the Mark Kitaoka shots one cannot really judge top & bottom edge illumination, so that would have to be taken into account when judging the test results to be different.
