Originally posted by mikeSF These show min power(5.0) and max power(10.0) from 1/1000-1/8000th sec on the K3II, adjusting ISO to accommodate exposure.
Thanks a lot for the test shots.
Not sure, though why you stated that there aren't any problems. Do you not see the gradient? The bottom part of the frame is consistently brighter than the top part; exactly what one would expect from a HyperSync solution (as opposed to HSS).
I'm not saying the solution produces unusable images but AFAIC, these images show the need for post-processing when using this technique.
