Originally posted by reivax Hello everyone, I've got a K-3. a Pentax 540 flash, and a handful of Yongnuo flashes. I've got wireless flash triggers, but none of them can do off-camera HSS. Can Pentax finally achieve this?
As others have posted you can use Acon triggers to achieve off-camera HSS, but only for your Pentax 540 flash. The advantage of using P-TTL HSS is that you get automatic exposure support and the disadvantage is that you don't get easy group control, manual level control, etc. from the camera position.
The Cactus V6 supports HSS in the way that has been posted already. You then need one P-TTL HSS flash for triggering and one or more RF60s as off-camera flashes.
The Cactus RF60 is the only flash I know that can be set to HSS mode manually. All other flashes require P-TTL communication to activate HSS illumination (which approximates continuous light for the duration of the exposure). You can use other flashes using the HyperSync technique, but that means that full power will be your only power level choice because if you reduce the power, the flash pulse won't be long enough anymore to illuminate all of the frame.
A way to achieve off-camera HSS lighting without any P-TTL equipment is the
"Starter Pistol"-method using the V6 again (but without optical triggering).
Hope this helps.
