Originally posted by DafTekno I was trying to use HSS to take shots in our garden.
I was trying to fade the background into darkness (also using 4-stop ND filter) and re-illuminate the foreground subject with HSS flash.
Garden had very bright natural exposure requiring 1/6000 ISO 100.
I always shoot iris wide open to get maximum 'depth of field effect' / minimum actual depth of field.
You will have a hard time to overpower the sun with a speedlite! Usually, people who want to achieve this use some high power studio strobes...
That said, you should still be able to underexpose the background a bit, although not fade it in darkness. First thing to do is to set your camera in manual mode and set the time at 1/180 (the highest flash sync you can achieve), ISO100. The reason for this is that at flash sync, or slower speed, your flash can give you its max power. Then, close down the aperture to get a correct exposure. This will be your starting point and the largest aperture you can use without using ND filters. Now, if you want to underexpose the background, you close down the aperture for the # of stops you want to underexpose. Obviously, your flash have to be powerful enough to provide enough light to get a correct subject exposure. And there will be a point where it will not be possible to close more without getting the whole frame underexposed, the flash not being powerful enough. Outside in daylight, you may not be able to get more than half or 1 stop underexposure without hitting the flash power limit...
Now, if you don't want the close the aperture, you could add ND filter instead of closing down. But since the ND filter also cut the light from the flash, you will have the same limitations as above, the difference in exposure between the background and subject staying the same. For example, you will not be able to get more than half stop difference, but at F5.6 instead of F11...
But, in these situations, it's usually easier to make do with the bright ambient light and just use the flash to fill shadows by dialing negative flash compensation... You can use large aperture if you wish to and a speedlite usually have enough power to do this instead of having to over power the sun. And this is were HSS is really useful: to get a fill flash using large aperture at fast shutter speed.
