05-07-2016, 08:16 PM   #1
Flash lag on K1
Has anyone had the chance to test if there is a lag in pttl mode using the K1?
The K3 in any of the auto ISO modes sets the Iso at 800. Does the K1 do the same?
Thanks
05-07-2016, 08:37 PM - 1 Like   #2
enoeske's Avatar
QuoteOriginally posted by derekkite Quote
Thanks
I just tried my K-1 with the AF540FGZii. Camera in manual mode, flash in P-TTL mode. There is a slight delay for the pre-flash, but hugely improved from the K-3. I am not able to lift my finger above the shutter button before it takes the shot. Previously, I could fully extend my finger after hitting the shutter, but before the camera would take the exposure. Again, much much better.
05-07-2016, 08:49 PM   #3
I agonized over the potential delay when buying the flash for my K-5. In actual use, I have noticed no delay of any significant consequence for what I do.
05-07-2016, 09:13 PM   #4
enoeske's Avatar
QuoteOriginally posted by pathdoc Quote
The K-5 didn't have any delay issues, just consistency issues
05-07-2016, 09:15 PM   #5
Otis Memorial Pentaxian
Not on my K-3. You might want to review your settings. Mine is set 100-3200, Standard ramping.
05-07-2016, 09:23 PM   #6
Class A's Avatar
QuoteOriginally posted by enoeske Quote
Thanks for sharing!
I normally shoot manually which means zero delay, but sometimes HSS can be useful and then there is no way around the (normal) P-TTL delay, so the fact that the K-1 addresses the unnecessary extra delay introduced by the K-3 is very good news.
05-08-2016, 12:33 AM   #7
Paul the Sunman's Avatar
Very pleased to hear this.
05-08-2016, 12:34 AM   #8
mcgregni's Avatar
Does anyone know if the lag still occurs with the K3II (using a flashgun) ...I mean with the K3 it was not just related to the built-in unit was it? So I wonder if it was addressed for the K3II and fixed?
Good news about the K1!
05-08-2016, 06:29 AM   #9
Thanks. Sounds like one more reason to not buy it disappears.
05-08-2016, 07:08 AM   #10
mcgregni's Avatar
Ha! No one seems to be coming up with any reasons ... Quite a surprise really around here.
05-08-2016, 08:01 AM   #11
I'd be pleased to hear you elaborate on this. I've had inconsistencies in exposure to the point where I started shooting in Raw specifically so I could better correct them. For the intended use, the ceiling is too high to bounce off (and sometimes I'm outdoors and there IS no ceiling!) and direct flash is the order of the day. Ironically, my old AF200Sa works better at direct flash within its limited range but isn't powerful enough, doesn't do bounce (for when that's an option) and isn't weather sealed (for when that matters).
05-08-2016, 08:15 AM   #12
enoeske's Avatar
Its had a hardware flaw in the metering system that resulted in very inconsistent results with flash, especially when bouncing.
05-08-2016, 10:54 AM   #13
Interesting. Further sources?
05-08-2016, 05:31 PM   #14
Google "K-5 flash issues"
05-08-2016, 07:42 PM   #15
enoeske's Avatar
PF interview with Mr. Kawauchi, @ Pentax Tokyo headquarters.
Q: Has the bounce flash overexposure issue that plagued the K-7 and K-5 been fixed in the K-3?
A: Since the K-3 features a new metering system, Pentax is not aware of any overexposure problems with P-TTL flash and the K-3. We believe this issue was originally caused by a hardware problem.
flash, iso, k1, lag, lighting, photo studio, strobist
pentax k1 with shoe mount pttl flash, shutter lag? ontariomark Pentax K-1 10 05-08-2016 08:44 PM
K-3 II rear curtain flash issue (not lag) Rayn Pentax DSLR Discussion 6 10-26-2015 11:42 AM
Flash lag fixed / FW 1.21 ScooterMaxi Jim Pentax K-3 47 07-01-2015 07:36 AM
Pentax k3II has the shutter lag problem wtih external flash ontariomark Pentax K-3 24 06-09-2015 12:56 AM
Pre-flash to flash time lag? Raven Flashes, Lighting, and Studio 3 07-24-2008 06:57 AM
All times are GMT -7. The time now is 05:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
