Originally posted by mcgregni Sigh. ..... But HSS is, well, just more cool!
Yep! Agree! But in the specific situation mentioned is this thread, with one flash not supporting HSS and only one pair of RF triggers, I'm not sure the HSS way is the easiest one...
As an aside, I use the 360 a lot (owns two of them and yes, the battery door is broken on one and barely hold on the other) and find that HSS with this flash is mostly useful for fill light. In HSS mode, competing with direct sunlight, it just isn't powerful enough to be used as key light, even more so with a light modifier. However, it works fine at sync speed, but may need to be set at full power with a light modifier and not too far from the subject.
