Thanks ClassA ....I'm pleased to hear that a free firmware update will allow the RF60 to recieve the trigger signal beyond the max sync speed from the new V6II model
.That means that I can just get one V6II and have an easy one flash, radio remote HSS solution.
I doubt that I would go the whole way and get a second V6II to use with a Pentax 540 .... really, its rare situations where BOTH slaves flashes would be out of range and/or sight of an optical trigger signal from the camera position. I find that generally its only one of the flashes that gets obscured. Having the Cactus radio triggered will give me far more freedom in positioning things as I will not have to try and send the optical signal flying in different directions (like using the Gary Fong Lightsphere as in my HSS demo) .... I can just set the Pentax flash in line of sight, that will make it a lot more easy, and for not much more money.
I didn't want to re-ignite the Manual / P-TTL flash wars ... not at all
. My point was very limited to the fact that manual flash exposure control for HSS work requires the additional step of making compensating power adjustments for every exposure time change. If you're juggling ambient exposures due to changing light, or just needing to experiment, then manual flash power is going to be more work in the HSS situation. I have found the P-TTL solution very reliable and the flash exposure will hold very steady while you make aperture, ISO and shutter adjustments to get the balance of things right. There will be times when that extra convenience is great, and other times when the better communication aspects / reliability of signals with the radio solution will be more important.
Really, there are good situations for choosing both automatic flash and manual flash. Professionals will go with what gear they like and what works best for their particular commercial needs, and many professionals work with a lot more support, backup, more money etc than most of us enthusiests, so what the Pros are doing is not always going to right for all of us. I quite like Neil Van Niekerks approach to this question, as he advocates, sensibly, the use of both Manual and TTL working, and he lays out a few scenarios where each makes particular sense. I follow these same principles and will normally use P-TTL on-camera, which I find invariably the best way to go, combined with Manual camera mode (there;s no contradiction there at all
)... its just the best way to manage and control the balance of lighting in the scene .... having a firm control of ambient exposure in Manual mode makes sense in fixed lighting scenarios .... but equally having automatic flash exposure in the same situations makes sense because both you and the subjects may be moving around within that fixed environment, so your distances and bounce angles can be frequently changing .... so P-TTL makes perfect sense there.
Likewise when the subjects are more static, and there's more time, then of course I agree that manually set flash power will give better control and remain stable throughout .... that makes sense in that kind of situation.
Thanks for clarifying the questions about how a P-TTL flash will work with the V6II for HSS. I see now that we will have manual power control (via the V6II units) plus zoom control, another plus! For me for now, I do find two new V6II units to be pricey for me, so I'll stick with one for the RF60, and keep using P-TTL HSS with the two AF-540s combined with the RF60 by radio control . I could also use my original V6 on a Pentax flash for manual power control (non HSS) when needed, that is something I'd like to try, having two groups under manual control ..... I might even enjoy that ... a bit ...
