07-01-2016, 12:20 AM   #31
mcgregni's Avatar
QuoteOriginally posted by Flasher Quote
One strange thing I have just had a play with my K3 and when in Av the minimum shutter is 1/125 at f2.8 even in a dark room. You mentioned 1/60.
Turn the flash off and see what the shutter is (should be slow in a darkened room), turn the flash on and see if the shutter changes up to the minimum. Point the camera out the window to daylight and the shutter should go to the max shutter (1/160 or 1/180 on K3 and perhaps 1/200 on K-1?)
Of course the K-1 may be lower min shutter and I am using 1/3 EV stops not 1/2 so that may be the difference.
You need to use Slow Speed Sync mode for that to happen when in an auto-exposure mode ....
take a look at my guide, it has a lot of details of all these modes, including A mode ....
07-01-2016, 12:37 AM   #32
QuoteOriginally posted by mcgregni Quote
No it was because I had zoomed in with my 28-70 lens. Zooming out set the shutter to 1/60th. That was in leading curtain sync. I had forgotten that zooming changes min shutter when in Av.
07-01-2016, 01:06 AM   #33
Otis Memorial Pentaxian
clackers's Avatar
But you only have a minimum speed because you're not in Slow Sync.
You're so stubborn. You should listen to McGregni.
07-01-2016, 01:10 AM   #34
Oh ok sorry I didn't realise that's what he was saying, my apology.
---------- Post added 07-01-16 at 06:45 PM ----------
Yes that was a misunderstanding, my original comment was just to point out that my minimum shutter was different to Sinus. I realised slow sync will allow lower but that wasn't my point. Sorry about that McGregni.
07-01-2016, 05:31 AM   #35
Thank you guys,
It was a great lesson. Now I have to practice.
First task is to figure the right settings for family pictures with fireworks as background...
07-01-2016, 09:34 AM   #36
mcgregni's Avatar
Glad its cleared up ... just to be precise, the exposure time restriction (which is related to focal length, as Flasher was saying) only applies to P and Av modes in practice. In Tav, Tv and M modes its not a valid flash mode because the time value can be set directly. So Slow Speed Sync is really a kind of temporary override of the limitation for people carrying out all-auto flash photography, the sort of thing you might use for portraits in low light when you want to record a balance between a dark background and a flash-lit subject ..... the typical example of this is the twilight cityscape scene. But then, we're not going to be using automatic exposure modes for that sort of thing, are we, we're going to using manual plus P-TTL, right ?
07-01-2016, 10:19 AM   #37
QuoteOriginally posted by sinus007 Quote
Last time the ambient light was calling for 1/80, F2.8, ISO 4000 = LV 4 for the fireworks.
Usually you want more trails in the fireworks itself, so you go for longer shutter speeds than what I wrote and can go down with ISO to balance.If you have people in the frame, so probably can not go too long with the shutter times.
But the main challange for your scenario is that the 540FGZ is so powerful that at the above settings it can not limit its own output enough, so that it shows a minimum subject distance of 8 meters.
Assuming that you would want to employ a wide angle lens that will create small people with an even smaller fireworks background.
So you would need some filter on the flash head to reduce its output beyond what it can do itself.
07-01-2016, 10:59 AM   #38
UncleVanya's Avatar
QuoteOriginally posted by beholder3 Quote
Or shoot multiple exposures - expose the people in one and the fireworks in another.
07-02-2016, 03:11 AM   #39
Good thread on the K-3 area about fireworks.
Best answer on the first page is probably this one from WPRESTO....I will second or third recommendations above: 1) prefocus (turn focus to manual, off of AF)2l) low ISO and small f-stop (ISO 100, f11~16 - - fireworks are very bright, too high an ISO will burn out all the color); 3) tripod with remote release; 4) set on bulb and keep the shutter open as several skyrockets go up. The images generally look better with multiple overlapping explosions.
And as UncleVanya says do multiple shot composite. If you want it in one shot then set the flash to trailing curtain sync. I haven't tried but it should work with Bulb mode. McGregni might be able to confirm that.
Read more at: https://www.pentaxforums.com/forums/172-pentax-k-3/324640-shooting-fireworks-...#ixzz4DFDrbx8c
07-02-2016, 04:46 AM - 1 Like   #40
mcgregni's Avatar
I don't know about that ... Based on how this thread started out, its amazing that its morphed into one about shooting fireworks with a flash-lit subject ! Quite a sophisticated technique to get looking really good. I'd say that for practising and getting to grips with flash exposure modes and ambient light / flash balancing, that much simpler scenarios would be better to perfect first.
af540fgz p-ttl vs, bug, camera, check, compensation, f2.8, f8, fault, flash, k-1, k-3, lighting, mode, p-ttl, photo studio, photos, pm, post, question, settings, shoe, strobist, subjects, sync
Flashes that work full P-TTL on a K-30 redimp Pentax K-30 & K-50 7 01-30-2013 02:36 PM
P-TTL and A-series lenses on 645D? alunfoto Pentax Medium Format 3 02-10-2011 11:43 AM
P-TTL vs Canon E-TTL Taikonaut Troubleshooting and Beginner Help 2 04-22-2009 07:28 PM
AF540FGZ, Sto-Fen and P-TTL Ed in GA Flashes, Lighting, and Studio 3 04-02-2007 10:03 AM
P-TTL VS TTL.... what is the difference to the average user? slip Pentax DSLR Discussion 16 01-17-2007 12:22 PM
All times are GMT -7. The time now is 11:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
