06-30-2016, 05:59 AM   #16
mcgregni's Avatar
I believe the test button always emits a full power burst regardless of any setting ....?
06-30-2016, 06:02 AM   #17
QuoteOriginally posted by mcgregni Quote
You have been told incorrectly mcgregni.
06-30-2016, 06:12 AM   #18
mcgregni's Avatar
Ok, thanks, then if we're sure that the testing has been correctly made and that the flash is not cutting it's output when dialed down, then its faulty. ... But are we absolutely sure?
06-30-2016, 06:30 AM   #19
12345's Avatar
FWIW, when my YN-560 IV arrived from Adorama, I went through this same process, and eventually figured out that it was in fact faulty.
QuoteOriginally posted by Flasher Quote
If you think it is a flash problem then take it off the camera and set it to Manual Full Power. Press the Red button and see how long it takes to recharge. Full power will be very bright and take a few seconds to recharge with the usual squealing involved. Now select 1/64 power and repeat. It should be a quick short flash and there should be no recharge time (ie the red light doesn't go out and no inverter squeal).
This was what eventually confirmed it for me. With my YN-560 III, I could set it to 1/64, and it would recycle so fast that I couldn't even tell that it had recycled! However, the IV had the same long (4-5 sec) recycle time regardless of the flash power setting. I returned it, and had to pay more to get it replace with a new one. (I bought it used originally)
06-30-2016, 07:45 AM - 1 Like   #20
Phenix's Avatar
Returned to the store already. They will try to fix it first. I only showed them the manual testing off camera. They took it back no problem. Thanks everyone.
---------- Post added 06-30-16 at 10:47 AM ----------
af540fgz, aperture, camera, f8, flash, ft, iso, lighting, mode, output, photo studio, pm, post, power, pttl, recharge, repeat, settings, store, strobist, subject, target
K1 + AF540fgz(I) no AF assist, Hss and PTTL errors (only for me?) sunCrm Pentax K-1 6 06-13-2016 04:44 PM
Night Full Moon's Power kyricom Post Your Photos! 5 06-13-2016 05:50 AM
JJC FB-4 power supply for AF540FGZ UncleVanya Flashes, Lighting, and Studio 5 09-01-2015 06:28 AM
For Sale - Sold: AF540FGZ & TR 3 Power Pack Ed n Georgia Sold Items 6 03-24-2011 11:34 AM
For Sale - Sold: AF540Fgz or AF500 FTZ Power pack TR2 Peter Zack Sold Items 4 06-22-2008 09:24 AM
All times are GMT -7. The time now is 08:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
