I'm new to flashes, but I've found that lowering my shutter speed, getting a faster aperture, and raising my iso can only get me so far.
Since I'm new, I was thinking that p-ttl can help me get started, I generally fall into the buy once, cry once camp when it can be helped (meaning I want a flash I can keep for the long-haul) and I found some deals on on the af-540fgz v1 online. ~200 to 230
I just wanted to double check and make sure that the 540 v1 worked well with the k-1. I've seen one flash review on this forum which mentioned that it was compatible, but I like to double check facts before spending over 50 dollars.
If there are any other flashes in that price range one could recommend with similar features and/or performance, I'd be all ears.
