07-17-2016, 11:16 AM   #1
BigMackCam's Avatar
YN560-IV and YN560-TX - Pentax compatibility
I'm considering getting a couple of Yongnuo speedlights and a TX control unit. Are there specific versions of the YN560-IV and YN560-TX that work with Pentax, or are they all one version that works on any recent camera? I see some advertised for Nikon, others for Canon, and yet others for Nikon, Canon, Pentax combined!
Thanks in advance...
07-17-2016, 11:37 AM - 1 Like   #2
virusn3t's Avatar
I use the Nikon version of the YN560-TX, so far no problem with the K30, K3 and K1, as far i understand the Canon version have diferent ping location that it make the transmitter get stuck in the hotshoe, that happen to me with a Youngnuo Canon transmitter (dont remember the model) and the K30.
About the flash, all of the YN560 1,2,3,4 version are all manual with the center pin only, if you can purchase only the v3 as is more cheap than the v4 and are basically the same, maybe buy one v4 when you need 1 flash in the hotshoe
07-17-2016, 11:59 AM   #3
ramseybuckeye's Avatar
I have the YN-560-IV and it works fine. I think it works with all systems. The !V can be used as a master or slave what I can understand. But I have not done so only having one.
07-17-2016, 12:26 PM   #4
BigMackCam's Avatar
QuoteOriginally posted by virusn3t Quote
QuoteOriginally posted by ramseybuckeye Quote
Thank you both - much appreciated
07-17-2016, 04:51 PM - 1 Like   #5
Logics's Avatar
With the Nikon version of the YN560-TX, the wake-up feature works on the Pentax K-3. However, the camera still has no idea that a flash is in use and will not limit shutter speed to below max sync speed of 1/180s. I do not know the behavior with the Canon version in either scenario.
The Nikon sync cord for remote trigger will not work with Pentax; you need the Canon (or any generic) ¼ inch stereo mini plug to do remote trigger (with an appropriate Yongnuo transceiver). Remember, the YN560-TX, although it is a transceiver, (in that it can receive a signal), neither it nor the YN560 IV flash guns have transmit buttons to half/full press to trigger the YN560-TX (although they have “test” buttons). The RF602, RF603 or RF-605 will work just fine (although I have not tried them personally, yet).
When using the Pentax Hot Shoe Adapter F (along with the Off Camera Shoe Adapter F & extension cable F5P/F5PL), and a YN560-TX is mounted on top, it must remain on for a P-TTL flash to work. Turning the YN560-TX off will immediately trigger the flash which will, from that point on, fail to trigger with camera shutter. Except for that caveat, they work well together. (Do not try in P-TTL mode, however, as the Yongnuo flashes may interfere with the P-TTL readings).
Along with two Sigma EF-610 DG Super PA-PTTL flashguns, I have one YN560-TX transmitter (Nikon version) and four YN560 IV flash guns. Will be buying more YN560 IV flashguns soon plus an RF-605N transceiver pair (they only come in pairs)..
P.s., Speedlight™ is a trademark of Nikon and Speedlite™ is a trademark of Canon, although Yongnuo and others seem to not mind using the term, “Speedlite” in reference to their flash guns.
07-18-2016, 01:13 PM   #6
BigMackCam's Avatar
QuoteOriginally posted by Logics Quote
OK... but I assume that as long as I manually keep my shutter speed below 1/180s, I'd be fine, yes?
I'm a little confused as to what this means for me... Are you saying that I wouldn't be able to trigger the camera's shutter and the flashes from the transceiver or flash units? If so, that's not an issue, as I'd be firing the shutter using the camera shutter button, or possibly my Pentax IR remote. Am I missing some other limitation?
Again, my lack of understanding shines through here! Can I ask, why would I use the transceiver with the Pentax Hot Shoe Adapter? In fact, what purpose would that adapter serve in isolation?
Many thanks for the detailed reply!
07-18-2016, 01:17 PM   #7
virusn3t's Avatar
Use the yn560tx nikon and the youngnuos 560v3 or v4 you will be fine, once linked (the more confusing step) you control as a dumb flash right from the transmiter, using 2s delay, remote, ir remore or you cellphone with the app
07-18-2016, 02:38 PM   #8
Logics's Avatar
Yes! completely correct.
Again, correct. I also usually trigger my camera with the shutter release or the IR remote. But the shutter can also be triggered with a Yongnuo RF602/603/605 transceiver (had I had one). ;-)
The only purpose for the adapter is for an off camera flash, using either the F5P or F5PL cord and the Off Camera Shoe Adapter F (not to be confused with the Hot Shoe Adapter F which goes on the camera, nor the Hot Shoe Adapter FG which also goes on the camera but has no has no pass-through connector).
I also have two Sigm EF-610 DG Super PA-PTTL flashguns. To trigger them, they either have to be in optical slave mode (Manual) or one of them needs to be connected to the camera in master/commander mode while the other one is in remote slave mode. The hot shoe adapter F has a P-TTL passthrough on top. I put the YN560-TX there and put one of the Sigmas on the off camera adapter up to almost ten feet away. (I have a 1m F5P coiled cord and a 3m F5PL straight cord).
Lately I have been using them in optical slave mode (which means, I have to go to each flash to adjust them) but with the Hot Shoe Adapter F → F5PL → Off Camera Shoe Adapter F, I can control the output of the Sigmas (to some extent) from the camera.
No problem. I may retire the Sigmas and buy more YN560 IVs and/or buy two sets of YN RF-605Ns to control them. (So far, they cannot work with the Cactus V6).
http://www.bhphotovideo.com/c/product/41177-REG/Pentax_31022_Hot_Shoe_Adapter_F.html
http://www.bhphotovideo.com/c/product/112755-REG/Pentax_31046_Off_Camera_Sho...geID/accessory
http://www.adorama.com/pxhsafg.html
07-19-2016, 10:46 AM - 1 Like   #9
BigMackCam's Avatar
@virus3nt - thanks, Julio!
@Logics - thanks, Karim, this is very helpful, and the picture helps underline what you've described. I'm grateful for your help
07-21-2016, 07:56 AM   #10
em-tx's Avatar
Thanks for this thread. I am just before the purchase of set.
YN 560 TX (Nikon) + 2x YN 560IV for original K5. What I am intending to do is to trigger shutter with IrRC for long exposure where at the beginning or end I should have flash firing. Both flashes are of camera. Eventually I hope to trigger shutter and manually at my will to triger flashes. That should all work, no?
If the camera does not see the flash, and its more than 1/180 as long as I keep speed of camera and flash the same, would this be ok?
Thank you and greetings.
canon, flash, lighting, nikon, pentax, photo studio, strobist, yn560-iv and yn560-tx
Yongnuo YN560-TX Wireless Flash Controller vs Cactus Blacknight659 Flashes, Lighting, and Studio 65 12-18-2015 05:46 PM
Yongnuo YN560-TX Wireless Flash Controller disco_owner Flashes, Lighting, and Studio 17 11-22-2015 09:47 AM
K5, YN560 IV, RF 603N II's matt_lin18 Flashes, Lighting, and Studio 24 09-11-2015 10:50 PM
Alien Bees B1600 Flash Unit and Yongnuo YN560-TX dcpropilot Flashes, Lighting, and Studio 9 07-24-2015 12:01 AM
Controlling YN560 III with YN560 IV or YN560 TX T Evergreen Flashes, Lighting, and Studio 9 02-10-2015 08:52 AM
All times are GMT -7. The time now is 10:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
