Originally posted by Class A The grass isn't always greener on the other side, though.
The X1 hardware isn't as ergonomic as the V6II hardware and the X1 firmware is constantly being revised. There is a never ending discussion of problems, bugs, workarounds and detective work posts on what an undocumented custom function may do at the respective TruthHavoc page.
If one does not need automatic exposure then I think the V6II (works with a large range of Pentax cameras, including the K-1) is the much better product.
I have Godox flashes and triggers for my Canon gear and I want to say that it will be a huge step forward for Pentax if Godox will start producing TTL flashes and also triggers for Pentax.
While Cactus has V6 triggers and RF-60 flashes, Godox has an entire system and is quite reliable, despite some minor problems they had with X1 triggers (problems that were solved after the last firmware).
My AD180 flashes work very good and I can trigger them and control their power either with my TT685 flash, either with my X1T-C trigger.
And if you take a look at Godox system you will see a lot of interesting products for strobist. They also came up with another trigger which is very user friendly. It's caled Godox XT32.
I really hope they will start producing TTL flashes (and triggers also) compatible with Pentax.
