Originally posted by jawsy If I fix a basic flash unit to the hot shoe of a K-3ii as a 'master', will a flash unit that is P-TTL slave capable of any brand result in a successful wireless flash fire?
You have been given a correct answer already, but you also asked in a rather specific way.
Depending on what you really mean by "wireless flash fire", other options are possible. "Wireless" (i.e., here that means "optical") triggering does not require P-TTL flashes at both ends.
If your on-camera flash is "basic" and your slave flashes are "basic" then optical triggering will work.
If your on-camera flash is "basic" and your slave flashes are P-TTL flashes then it depends whether they support optical triggering from basic flashes. Some flash models do.
If your on-camera flash is a P-TTL flash then many "basic" flashes can still be optically triggered because they offer a mode in which the pre-flash from the P-TTL flash is ignored.
So while the "both P-TTL" case is a clear cut one, all other three cases also support "wireless triggering". They do not support P-TTL exposure control but some flashes support a so-called "A mode" which is a different form of automatic exposure control. Also, your question does not imply the desire for automatic exposure control, so I think all four combinations are possible answers to a certain interpretation of your question.
Originally posted by UMC I confess, there may be small and cheap options from Metz too, but given the fact that wireless P-TTL obviously has a quite proprietary protocol, I'm not so much in favor of 3rd party products just to be on the safe side for future cameras.
Metz just released firmware updates to make their older flash models compatible with the K-1. Seems like at least in the case of Metz there is no need to be overly concerned.
