I just bought a new Pentax AF360FGZ II flash to use with my K-1 and existing Metz 52 AF-1 P-TTL flash. Preliminary testing indicates that the two flashes work well together wirelessly in either configuration: either the Pentax or the Metz on-camera as master or controller with the other as slave.
However, I was surprised to see that the included manual for the 360 refers only to APS-C, 645D, and Q. No mention, in the text or tables, of full frame (K-1) or even 645Z. The
on-line manual was the same.
So, is the AF360FGZ II full-frame ready, especially as regards zoom position and flash coverage? Certainly, in autozoom mode, it seems to register the correct focal length, though does it know that it is attached to a FF camera and therefore should use a wider light spread? A few tests suggest that it does provide adequate spread, so I am surprised the manual says nothing about it.
By the way, these two Pentax and Metz flashes are very good, with very similar functionality. They are almost the same price in Australia. For anyone tossing up which to buy, these are the differences I would note:
- The Metz 52 AF-1 is much more powerful than the Pentax AF360FGZ II (guide number 52 compared to 36).
- Perhaps related to power, the zoom range on the Pentax is 24-85 mm, and 24-105 mm on the Metz.
- The Pentax is more compact and a little lighter (290 g without batteries compared to 346 g).
- The Pentax is weather resistant, the Metz is not (or doesn't claim to be).
- The Metz cannot do HSS in wireless mode, the Pentax can (you would need two of them with the K-1 to take advantage of this).
- The Metz has an extensive touch-screen menu system, whereas the Pentax uses a more traditional buttons-and-dials interface. I am still getting used to the Pentax interface, but it seems quite straightforward. Which of the two approaches is to be preferred is a personal matter.
- The Metz firmware can be updated by the user using a usb connection, the Pentax cannot.
- Neither flash can use an extension cord directly; you need an adapter.
- The Pentax has a built-in LED light for catchlight (and some degree of continuous lighting for video), the Metz does not. However, the included white reflector card on the Metz does a good job with catchlight, and a 3-second modelling light is available as a "high-frequency stroboscopic flash".
- The included stand of the Pentax fits neatly in the supplied pouch together with the flash; this is not so of the Metz. However, the Metz pouch has a handy belt loop that the Pentax lacks. The Metz stand can be screwed to a tripod, the Pentax cannot.
- The Pentax has a release button to allow the head to be tilted (annoying), the Metz does not.
- The Pentax has something called Contrast Control Sync Mode, the Metz does not (explicitly). However, although I haven't used it, this seems to just be a way to have different powers set on the different flashes; that can be done directly on the Metz. CORRECTION: I have just found "Contrast Control" in the Metz manual, which seems to be the same thing. Both the Pentax and Metz manuals seem to suggest that this only operates in wired mode, with attendant accessories, but I'm confused about whether this is the case or not. Anyway, it seems easy enough to adjust the power compensation on each of the master and slave and get whatever balance you like. So I don't really understand Contrast Control mode.
So far, after only very limited testing of the Pentax, I can recommend both units. I particularly appreciate the added power and updateabilty of the Metz, whilst the compactness and WR of the Pentax is appealing. Apart from the HSS issue, they pair well together. As far as I know, the AF360FGZ II is the most compact option capable of acting as a master or controller in lieu of the pop-up on the K3 II or K-1.
