Originally posted by Class A Is it just the display of the zoom figures that is wrong, or is the angle of view of illumination achieved by the flash incorrect?
Realized that I was wrong in saying the flash zoom will track the lens zoom when off camera, but it is still not working correctly when controlled from the V6 II Tx.
If I set 16mm zoom on the V6 II Tx I get 24mm on the flash (actual zoom position and display value)
If I set 20mm zoom on the V6 II Tx I get 28mm on the flash (actual zoom position and display value)
On a 645Z the ratio should go the other way. The flash should be set wider than the 645 focal length to account for the scale factor between the camera and the flash with its 35mm-based zoom levels. If I have the flash directly on camera with the 55mm lens the flash will zoom to 35mm, which is the closest zoom level it has. This is how it ought to work, but it's working back-to-front on the V6 II.
