Originally posted by Jerry62712 It's optical (Metz 52/58) for wireless I assume.
Metz supports wireless (optical) P-TTL in master, controller and slave modes. You can set Servo mode to synchronize with or without pre-flash as well (but you can't set a remote channel, it will fire from any light source).
Originally posted by Jerry62712 Will it do second curtain wireless?
I have the 52 AF-1 and second curtain, or rear synchronization can be set, but the manual says it will be cancelled or ignored if the camera doesn't support it or allow it (when red eye reduction is set, for instance). The manual doesn't specifically say second curtain sync won't work wirelessly and I've never really tested it. IIRC Metz had to reverse engineer the P-TTL protocol, but I haven't seen anything to indicate this is something the Metz can't do, while the Pentax models can. In other words, if rear curtain synchronization can be done with wireless P-TTL, the Metz models should be able to do it.
There are settings for contrast control that might only be possible with a Pentax flash, but your K-50 doesn't have the capability to change contrast control settings, so unless you plan to upgrade to a higher end model like the K-3, I don't know of anything a Pentax flash can do that the top Metz models can't. (Sorry, I just remembered that one of the Pentax models has a white AF assist light, whereas the Metz uses red, so it can't be used as a make shift flashlight. Or something like that, the only Pentax flash I have is an old AF200T, so I could be out to lunch).
