Originally posted by mcgregni To be sure that it's not just recycling variations, have you tried it on manual mode at low power and fired a few rapid shots, then a pause , and then another burst? That would at least eliminate any charging delay caused by power drain. If it can't fire, at low power, every 1-2 secs with good batteries, then there is a problem.
I did try this.
Set to manual, adjusted power to different settings and used the "test" button. Then tried new batteries, same issue. After a few min it just started working again. I just tested after it has been sitting over night unused, new batteries, no issues.
I don't think it is overheating since I only took about 16 photos before it quit working.
One thing comes to mind..... It didn't start happining until I turned the flash head to the right to do a bounce flash. Are you all aware of any wires that might be getting pinched?
