I bought a Pentax AF360FGZ II a couple of months ago, and have been using it on both a K-3 and K-1 without problem. However, suddenly it no longer seems to recognize the camera (either one). In particular
- The auto zoom doesn't work, it just stays at 16mm.
- The shutter speed on the camera can be increased beyond the maximum sync speed. It won't fire in that case though. If the shutter speed is below the sync speed, the flash will fire, but the exposure is horrible. P-TTL doesn't seem to be operating correctly. (Yes, it is in P-TTL mode)
This is quite perplexing . I don't know why the flash has suddenly started doing this. It is as if the flash and camera are barely communicating. The first thing I looked for was a reset button on the AF360, but I can't seem to find one.
Does anyone have any suggestions about what could be causing this, or how the flash can be reset to "factory"?
