Originally posted by fritzwd Ben:
This sounds exactly like what is happening on my Pentax K100d Super which is a p-TTL camera also with TTL as explained in the instruction book. It says if the flash used is not p-TTL it will default to the TTL mode. However, should the camera not automatically adjust the aperature (f-stop for the correct exposure? This does not seem to be happening. Am using a Quantaray 9550U with a dedicated Flash module for an auto focus camera. See my question at bottom of site.
I am a Pentax user since the first Spotmatic ( 1968 ) and still have loads of the old SMC Pentax lenses.
THanks
Bill Fritz
The camera cannot chose a matching aperture if you use a TTL-flash mode, which does not work with the camera. Depending on the flash module, this may work in AUTO-flash mode (which uses the flash's sensor, instead of the camera sensor). At least Metz flashes with SCA adapters transfer camera settings to the flash and vice versa. I am not sure about Promaster, though.
Ben
