12-27-2017, 02:02 PM   #121
mcgregni's Avatar
Hi neonalog ....I'm glad you found the Guides useful!
You are mostly right about the different features of these two budget flash options. The Shanny does not support Wireless P-TTL, therefore it only does HSS when on the camera. The Slave functioning is the 'dumb' optical type.
The Yongnuo can function as a Wireless Slave, but not as a 'Master/Control' unit. I don't know if it has 'dumb optical' Slave capability.
Finally there is nothing different flash-wise between the K20 and the models just after it, so any P-TTL flash should be expected to work correctly with that camera.
12-27-2017, 04:42 PM   #122
QuoteOriginally posted by mcgregni Quote
Your Guides are really instructive!
Based on what I've read, the two flashs only can be used as slave, in the "dumb optical wireless" way, as it. The difference, I don't know why, is the Shanny can only be used in Manual mode, and the Yongnuo in full P-TTL, in optical wireless.
Furthermore, the Shanny does support HSS, the YN585 doesn't. I think the confusion here comes from many webshop's description wrongly teasing about speeds up to 1/20000s as I could read for the Yongnuo... It is NOT on the official notice of course.
And finally, I read about some possible incompabilities with the AF-assist beam and the K20d, maybe another "dumb" idea in the air ...?
12-28-2017, 12:15 PM   #123
YN585 is available in case any one insterested..
($66.96 + $7 shipping on Adorama)
($79.00 at BH)
01-15-2018, 06:45 AM   #124
Will this flash work for the rear curtain sync? If not, what flash will work on rear curtain sync? I'm using a k-5II and a k-3II. Thanks.
01-15-2018, 08:43 AM   #125
mcgregni's Avatar
The Pentax AF-360FGZII and AF-540FGZII both offer rear curtain sync on-camera. This is a P-TTL subset function only (only available in P-TTL flash exposure mode).
01-15-2018, 03:59 PM   #126
QuoteOriginally posted by totsmuyco Quote
If you're speaking about the Yongnuo 585, yes, it does support rear curtain sync too. Great flash for the price..
01-15-2018, 04:39 PM   #127
Thanks for all your tips. I think I'll proceed with getting this flash.
04-28-2018, 05:24 PM   #128
madbrain's Avatar
One ebay seller is claiming this flash has HSS support . Is it B.S., or has there been a firmware upgrade that enables it ?
YONGNUO YN585EX P-TTL HSS Flash Speedlite for Pentax K1 KS1 KS2 K3 K70 K50 O1S2 758232900277 | eBay
I am looking at possibly getting this flash for my upcoming K-1 . I don't need any fancy flash features but I would like something compact enough and that meters properly, hence P-TTL. This is mostly to make up for the lack of pop-up flash on the K-1, but I won't be using any wirelessly triggered external flashes.
Does this look like a good choice, or is there something more compact that would be better for my use case ?
04-28-2018, 07:21 PM   #129
The ebay seller is incorrect. The YN585EX doesn't have HSS, but P-TTL works well. There was a firmware update for the flash, but it doesn't add HSS.
If you want HSS, the Shanny SN600FGZ has it as well as P-TTL and is about $40 more than the Yongnuo
04-28-2018, 08:55 PM   #130
Just noticed that firmware Ver.1618 for the YN 585 has been available since Dec 2017. Installs fine, no noticeable improvements so far.
Ver.1618 2017/12/23
1.Improve compatibility;
2.Fix other bugs.
From the HK YN site:
Yongnuo Photographic Equiment Co., Ltd
---------- Post added 2018-04-29 at 01:57 PM ----------
QuoteOriginally posted by T Evergreen Quote
Can confirm.
I suspect HSS isn't something that a flash can do just via a firmware update anyway.
04-29-2018, 02:59 AM   #131
have they came out with a trigger for it yet ??
06-19-2018, 06:39 PM   #132
QuoteOriginally posted by markl62 Quote
Short answer? NOPE.
I've reached out to Shanny through direct email and social media multiple times and have never received a response.
They don't seem to keep up with their website either. I was tempted to get their trigger and a nikon version Shanny Flash and see what happens. As long as I could control the flash I'd be happy, but I believe their triggers are all i-TTL/E-TTL so I don't want to risk it due to the pins asking for the wrong things.
---------- Post added 06-19-18 at 09:43 PM ----------
I will confirm this tonight.
06-20-2018, 12:35 AM   #133
QuoteOriginally posted by Kobie Quote
Short answer? NOPE.I'.
It shouldn't be that f&^king hard should it ?? I raised that with Shanny at the time they introduced the flash and we are still waiting.
I have a couple of Godox flashes I use with a Cactus V6ii and XT32 trigger for Nikon. Still a bit of hit and miss in HSS.
Sometimes wonder why I stick with Pentax.
06-20-2018, 12:49 AM   #134
LensBeginner's Avatar
Uh... they are a third party so they just do things when they see that there's a market for them?
06-20-2018, 06:09 AM   #135
Short answer? NOPE.
Unfortunately I don't have another HSS capable flash to try this with. But in Slave mode with the Shanny, you can enable HSS. It is a full manual flash though in S1, S2 so I'm not sure how the HSS off camera would work unless it triggers at a quicker timing. I'd have to borrow another HSS flash to test this though. I don't think I can borrow my friends Metz flash since, well, now he's all into flash photography now lol
firmware, flash, hss, lighting, mode, p-ttl, photo studio, sound, speedlite, strobist, system, time, trigger, ttl, yn, yn585ex, yongnuo
Metz WT-1 radio triggers coming in 2017: P-TTL, HSS, groups, studio flashes beholder3 Flashes, Lighting, and Studio 42 07-03-2018 11:12 PM
Cactus optical triggering w/ P-TTL HSS flash - settings bobbotron Flashes, Lighting, and Studio 32 12-31-2015 12:05 PM
Strange Happening Wth Metz Flash In P-TTL/HSS. tabl10s Pentax K-3 11 04-05-2014 12:05 PM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
HSS with a non P-TTL Flash off camera? Not Registered Flashes, Lighting, and Studio 13 12-05-2007 12:12 PM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
