Originally posted by Class A I also would have thought this works. A number of people have used the V6II as an "HSS enabler" by stacking another trigger on top of it. For instance,
fwbigd used the Godox XT-16 and
Pablo Villegas used the Godox X1. There are quite a number of reports about successfully using other triggers on the Cactus community forum.
My guess would be that the camera system should be manually configured to "Pentax", the flash system to "Nikon", and the flash profile to "Auto". TTL pass-through should not be engaged.
I have X1Tn and XT32c. I bought into both systems hoping I'd be able to find a workaround while Godox and Cactus iron out their bugs.
I have 5 of the new Godox flashes (1 Nikon system and 4 manual).
I am a software engineer and looking at the systems as black boxes I can:
1. Clearly see inconsistencies in interoperability, including with time and device combinations (i.e. the sequence of events things are hooked up and set up can give different results). This is more pronounced with the X1T than with the XT32.
2. Cactus v6ii is clearly affected by the device that sits on top. I could never make K-1 fire above sync speed (both HSS and Power Sync modes) while the latter is possible with XT32 in
manual mode.
To me, I'm left with the following choices:
1. Waits for the firmware updates. It is clear to me though (from the Cactus representative replies) that stacking transmitters is not, let's say, encouraged. Future firmware can improve or deteriorate functionality.
2. Get FT16 - in the sister thread this was shown to be working.
3. Get a second v6ii. Hook it up to the Godox Nikon system flash, which conveniently has a master mode.this way I will fire the second v6ii which I turn will fire the rest of the flashes. I am not sure however if I can fire the rest of the groups with the master flash.
I feel option 2 is the best, though I may try 645D ... who knows, maybe the camera also affects interoperability of the transmitters.
And to conclude with the words of Arthur C. Clarke:
Any sufficiently advanced technology is indistinguishable from magic.
---------- Post added 10-05-16 at 11:18 PM ----------
Next thing on my list is covering the non-center pins of the interface between the transmitters. I read on the Cactus forum they had this bug but supposedly they "fixed-ed" it
Or maybe it was the Godox forum... long story short, setting the center pin operation was ignored with the previous firmware if more contacts were sensed.
