Originally posted by Markx I googled for a while and found about light tents and reflectors and they sound fantastic but sadly they are not practical.
Take box, cut holes in side, cover holes with diffusion material (copy paper, parchment paper, tissue paper, lots of options but be consistent), add desk lamps (with the same type of bulbs), camera on tripod and you're good to go. A sample construction:
Strobist: How To: DIY $10 Macro Photo Studio
Samples of what you've managed and examples of the type of photo you're trying to achieve would be a help, but a simple light tent is an easy and safe way to start.
Originally posted by UncleVanya With a watch - given that it is a mostly static subject I would just add some conventional light and shoot without flash myself. But I'm just that way. If you can't keep the second hand sharp and need more light than you can bring to bear I would look at diffusing the light from the flash first and then other techniques
Agree with the advantage of a what-you-see-is-what-you-get setup, especially if you're new at lighting. If you can't get the second hand sharp (and you want it sharp) can't most watches be stopped?
