The YN 560 is usable as a manual, optically fired, flash with a Pentax camera and a controller flash. The model that I have does not have it's own radio wireless capability and I don't think that the Metz 50 Af-1 flash has radio wireless capability either.
I have tried to use the same setup, as described above, on both the Pentax K-5 with the built in flash as controller, and now with the K-1 using a dedicated Pentax flash as the controller and the Metz flash acted the same using both camera's. Either slave flash will work in the expected mode, and the YN 560 will always fire, but the Metz flash will not fire in p-ttl mode with the YN 560 in the setup.
I don't understand why it won't work, but I have attempted to make the mixed manual flash p-ttl system work using only optical triggers several times. As I stated in the original post I expected that the YN560 would just fire in manual mode and the p-ttl flashes would attempt to set exposure.
As an aside it is possible to use the Metz in p-ttl mode with a control flash and fire the YN 560 in manual mode, but I had to resort to setting up optical wireless p-ttl and then firing the YN 560 using a radio transmitter connected to the camera pc port. This setup works as expected and flash compensation can be used to get a good exposure.
If anyone has the same setup I would appreciate confirmation that I'm not crazy!!
