11-18-2016, 09:10 AM   #1
Banned
The solitary Pttl&M&groups radio trigger in the world!
but allow me to say so.
I made a short video and right now upload. it take many hours.
basically, it is no different to the good old R930. but with OLED and some more conrols. I sholld add the words.. with OLEDs and dial?
11-18-2016, 09:59 AM   #2
mcgregni's Avatar
Hi Andy, is this a new version of the Acon? A good display and direct controls would be a real improvement!
There's no video linked ....it seems to be just an image of your screen.....
11-18-2016, 03:35 PM   #3
LensBeginner's Avatar
QuoteOriginally posted by mcgregni Quote
I guess he said he's in the process of uploading the whole thing, which takes time since it's video.
11-18-2016, 04:47 PM   #4
mcgregni's Avatar
Ah, I see .....I read it the other way, that the video took many hours to make.
11-18-2016, 06:19 PM   #5
Banned
You may say so.mcgregni.
But acon is to release version with different appearence. This one is for function evaluation. and require test user feedback.
11-19-2016, 04:04 AM   #6
QuoteOriginally posted by andy888 Quote
If they need K-1 testers: I'd be happy to volunteer and provide feedback.
11-19-2016, 04:27 AM - 1 Like   #7
mcgregni's Avatar
I'd second that, I'll look forward to your report! And really ClassA should have a set for some updated Acon vs Cactus comparisons ....
11-19-2016, 05:43 PM   #8
Banned
QuoteOriginally posted by beholder3 Quote
As I learned. the acon only look for tester in China.
The R930T sender and the original R930 share the same firmware core, the only difference is interface. If you have R930. you can also use some "group manual and Pttl mix".
Further, if you once have a R930T. it works with R930 receiver. and R930 sender can be programmed as a receiver too.
I think acon should concentrate on making good old R930 update. the UI improvement is hard to say if it is better. I don't think most people can make many manual work if they have TTL. The R930 UI is enough for "some times use manual and group for changing". then they would go back to TTL and EV.
flash, lighting, photo studio, strobist
Metz WT-1 radio triggers coming in 2017: P-TTL, HSS, groups, studio flashes beholder3 Flashes, Lighting, and Studio 42 07-03-2018 11:12 PM
Metz 52 PTTL & PTTL HSS Eder Flashes, Lighting, and Studio 5 06-19-2015 08:24 AM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
Does any B&M store have the K-30 in the SF bay area ? madbrain Pentax K-30 & K-50 3 07-26-2012 05:01 AM
For Sale - Sold: (AUS) SMC Pentax-M 50mm/1.4 & A35-105mm/3.5 & MV1 body & DB1 Grip (AUS) ddhytz Sold Items 4 04-22-2010 03:28 AM
All times are GMT -7. The time now is 08:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
