BTW, I just realized that the problem with the second frame in a volley always being black at Continuous Medium (wirelessly triggering the YN560-iii) only happens in Liveview mode. When you shoot in Liveview, the camera first fires three very fast frames, then slows down. But if you fire from the viewfinder, the frames are evenly spaced right from the beginning and then no frame is missed by the flash.
Originally posted by jake14mw Very interesting picture of the penny!
Thanks!
Originally posted by jake14mw Interesting. I just tried this with my K-5ii. Specs say the fps is 7, which is in between the H and M on your K-3. YN-560iii, triggered by RF603Nii. First try, on 1/16 power, fired every time, no problem. Then I realized my focus was in AF-C, which was probably only 5fps, changed it to manual, and got the same thing you did. Only fired on the first pic. Same thing on the second try. Then I turned the RF603 off and turned it back on again. Now, I cannot recreate it again, fires every time. Tried the YN560-TX, and that also fires it every time.
That's good to know! Looks like 7fps is marginal, since you did see the problem a couple of times, at least with the RF603Nii.
Quote: Before I tried it, I thought it was due to the fact of how close the trigger and receiver was in your setup. That can definitely cause problems between many triggers and receivers.
Do you mean that you can have problems if they're too
close? Because the distance for me is very small...
Quote: So, if I had to guess, I would say that the RF603 can only handle around 7fps.
That would be my guess too.
Quote: How many fps do you need?
Open question, and another reason for the tests. There are many things to consider. The key is I need to insure that there is sufficient overlap between zones of focus to produce a really sharp stack. This depends on FPS, but also the speed at which I can move, and the DoF produced by the lens combo I am using. Also, when shooting high magnification macro setups that involve reversed lenses, closing down the reversed lens gives slightly more DoF, but the more you close, the harder it becomes to find and focus on the critter, as even the liveview screen goes dark. I also need to stay aware of what the flash can do, based on the power I am asking for. I think shooting higher FPS should help both in allowing more open shooting with lower flash power, and requiring less high precision control of my own movements to avoid gaps. Clearly though, Continuous Medium with 1/32 flash power (and a reversed lens at F/11) is still marginal for me.
Quote: As you said though, this is just a temporary issue for you until you get your flash cord, which is much better than using radio triggers anyway.
Yes, I am testing options, but the plan is to eventually fire either off-camera with a cord, or even on-camera with a custom diffuser...
