Originally posted by mcgregni You yourself, am I right in thinking your use is limited to a single flash?
Okay, let's get this right, Nigel, because what you're saying will end up in Google and forum results on the topic, and there is an onus on you to be accurate.
I have a full Yongnuo setup. Three flashes and a TX controller, which has LCD display, groups, remote power and zoom, etc.
That's what I use for any photography in the home, with lots of different modifiers (I have a strip box, beauty dish, octabox, etc) and all in manual for the best control.
I have an Acon for heading out of the house to give me P-TTL and HSS on a single speedlight, but that's it ... I'll probably never buy another Acon receiver, unless I want a backup.
So, I have no idea what it's like using two at the same time. And other owners I respect - Rawr, Beholder, Mattb - don't either. You certainly don't!
So, if we don't have opinions, on who have you chosen to base your summary or consensus of all us contributors on the issue?
If you read in the forum from enough credible sources that having two receivers doesn't work ... that it's not the same as having two P-TTL cables coming out of one hotshoe, for example ... I'd like to see those posts.
It would be like someone reading the experiences of Wpresto and I, and concluding the firmware can't be updated. Rawr has shown us to be mistaken.
