Originally posted by deepbluish Does anyone have a clue what could have happened?
Make sure that you are able to provoke the camera's AF-assist light. For instance, the K-5's focus mode should be set to AF-S.
If you can make the camera use its AF-assist light then adding the flash (potentially using the right flash mode) should make the flash's AF-assist light come on.
I have noticed that Metz have removed some functionality in some of their latest firmware updates (support for analog TTL) for some models, and the K-1 cannot use the AF-assist light of the classic FGZ models, but I have never heard of a K-5 AF-assist light issue before (which does not mean that it doesn't exist).
