Show Printable Version 14 Likes Search this Thread
08-04-2018, 02:13 PM   #106
Do these triggers work with any PTTL flash? Are there receivers available?
The Priolite and Phottix radio triggers work with with advanced features like P-TTL and HSS support only with their own brand specific studio and location flashes/ receivers (as best I can tell). Ditto for the Cononmark triggers. But all of them will no doubt remotely fire any old flash in manual mode, FWIW.
Cactus triggers like the v6 II are - for the moment at least - the only radio triggers likely to work with multi-brand flash gear (Metz, Pentax, Sigma, YN etc) whilst also supporting advanced flash features like P-TTL, flash power control etc (if the flash hardware itself supports those modes).
The Acon R930 radio triggers offer direct P-TTL flash support for multiple flash brands. But they are hard to get nowadays.
08-05-2018, 10:53 AM   #107
QuoteOriginally posted by kaseki Quote
Sorry; I meant analog TTL -- that archaic technology the ancients used.
mcgregni: Upon rereading your tome, I would like to supplement my comment above by noting that what I was conceptualizing might qualify as auto-data-fill auto-A mode, except that it would potentially apply to an array of flashes controlled wirelessly via RF RX triggers and receivers. Sort of a Cactus V6II TX with a detector and TTL processing, and with the RX mode modules capable of strobe quenching upon command. I think that the Cactus units do dynamic quenching anyway when remotely controlled to one of the various power settings, else they would be limited to the power settings native to the particular flash head. However, at present I suspect that the RX modules just receive the required power setting from the TX module and use a timer to determine quench time based on the flash calibration. And, unfortunately, this conflicts with multi-flash TTL which normally quenches all flashes at once when the total received reflected power meets the desired level, with relative flash power on the subject determined by range, diffusion, etc. So there may be some control issues in this concept that need further thought.
08-08-2018, 10:16 AM   #108
For me, it was interesting to have a flash option with built-in radio control for other lamps and receivers with HSS and P-TTL, because I often use the Round Flash Ring lamp attached to the foot of the camera. This allows for the use of Acon or Cactus, but Phottix Odin not.
For obvious reasons, I also prefer to avoid fixing the flash on a cactus or other type of transmitter, because such a construction ceases to be stable - it is easy to damage any of the elements. Therefore, in the outdoors I am often forced to use either only the HSS lamp on the camera (which strongly limits the range of this lamp) or even giving up HSS and using manual control over the radio or P-TTL triggered by the flash of the Master lamp.
In addition, 600Ws and more powerful lamps are needed to use HSS - and there are no such lamps in the Pentax system. And that's what I meant by writing about skipping professionals by the lack of a system radio solution.
02-26-2019, 08:36 AM   #109
Hello!
I bought Shanny SN600FGZ.
But I have a problem.
My camera is K-S2. The flash does not work in p-ttl mode.
There are no problems with the Pentax Q10 and Pentax K200D.
I want to ask someone who has a Pentax K-S2 and Shanny SN600FGZ. And how is the P-ttl mode in it?
Is the flash and KS2 incompatible?
02-26-2019, 09:13 AM   #110
mcgregni's Avatar
Why do you believe P-TTL is not working? What exactly are you doing, and with what settings and equipment (ie lens), when it does not work as you expect?
02-26-2019, 10:24 AM   #111
I tested several lenses-DA 70/2.4 DA35/2.4 FA50/1.4 DAL 18-50 Tamron 100/2.8 Tamron 17-50/2.8
Frames are heavily overexposed.
I need to insert flash exposure Compensation -3EV and -4EV in the camera to get normal exposure at f2,8-f5,6.
As a matter of fact, I'm in a manual mode
02-26-2019, 04:37 PM   #112
Kobie's Avatar
QuoteOriginally posted by dsmt Quote
P-ttl - YouTube
https://www.youtube.com/watch?v=Z91JAiYIrrs&t=16s
What ISO are you using, Aperture, Shutter speed?
You mention
Do you mean Manual mode on the camera or Manual on the flash?
The flash itself is in P-TTL mode with the little camera icon on the flash display?
02-26-2019, 11:19 PM   #113
A few days ago I have realised that all my problems with sn600 fgz were caused by the automatic horizon correction. Try disabling this function in your your camera. Maybe this will help.
02-27-2019, 12:23 AM   #114
QuoteOriginally posted by Kobie Quote
You mention
The camera is in AV mode.
I make a series of photos with different ISO and aperture.
K-S2 makes overexposed photos. With Q10 the pictures are properly exposed.
To obtain properly exposed images with К-S2 with Flash in P-ttl mode, you must set -3 exposure correction in the flash , -3, -4 or -5 in the camera and -2 exposure correction the flash in the camera...........I say that the flash is in TTL mode, but in fact it works like a manual flash
Auto Horizon Correction not ON.
02-27-2019, 06:30 AM   #115
Check the hot shoe on the camera, ensuring that no foreign material is lodged in it. Also make sure that the flash is seating properly in the hot shoe. It may be that the pins on the flash and camera are not lining up properly/completely, so give the flash an extra firm push into the hot shoe.
03-05-2019, 04:25 AM   #116
BruceBanner's Avatar
I'm curious to know more about this flash, I'm wanting to know quite simply if when connected to a K-1 or KP it can do 1/1 power in HSS mode rather than being restricted to P-TTL HSS like the Pentax ones are. Do we have anyone that can confirm this yet? (with pics )
03-05-2019, 01:29 PM - 1 Like   #117
Kobie's Avatar
QuoteOriginally posted by BruceBanner Quote
The flash needs Camera communication for HSS to work, so.... HSS requires P-TTL and you can adjust the output -/+ 3 EV. I have the flash (but a K-3 and K-30) and have shown that the HSS works quite well both on camera and off camera using Cactus V6 II triggers. I've posted the videos on here before but I can link them as a comment if you want to see it actually working outdoors in bright light so you can determine (kind of) if it would be powerful enough for you. It is a pretty powerful flash to be honest.
03-05-2019, 04:10 PM   #118
Thank you Kobie. There seems to be only one flash that will work on a pentax camera that can manage manual mode AND do HSS, which is the Godox TT350P, slightly underpowered. I was hoping this brute might manage that feat as P-TTL errs on the side of fill light rather than key in a lot of situations. I've keen to use my Vello Round Flash box with on camera flash at 1/1 and be able to shoot wide open and on days where I need to pass 1/200 in order to achieve that.
I wrote all about this in this thread over here >> 3rd Party Flash for Pentax that HSS in Manual Mode (from the hot shoe)? - Page 4 - PentaxForums.com
03-05-2019, 04:21 PM   #119
Kobie's Avatar
Not sure if this will help at all, but figured I'd link it anyways.
from 0 to +3 EV HSS.
03-06-2019, 07:59 AM   #120
Kobie, thanks for the videos. You mention in the first video something about using HSS in both P-TTL and manual modes. Can you expand a bit about HSS in manual mode as there was nothing in the video about this?
Also the specifications for V6II say it supports power sync (hyper sync). Is this something that works with the Shanny or only with a Cactus flash like the RF60x?
accessory, button, camera, control, flash, flashes, hss, k-5, light, lighting, metz, mode, on-camera, p-ttl, p-ttl hss flash, pentax, photo studio, power, press, rise, shanny sn600fgz p-ttl, shutter, sn600fgz p-ttl hss, strobist, sync
Cactus optical triggering w/ P-TTL HSS flash - settings bobbotron Flashes, Lighting, and Studio 32 12-31-2015 12:05 PM
Strange Happening Wth Metz Flash In P-TTL/HSS. tabl10s Pentax K-3 & K-3 II 11 04-05-2014 12:05 PM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
For Sale - Sold: Metz 54 MZ-4i Digital Fully Automatic 54 GN P-TTL HSS Strobe Flash for Pentax wallyb Sold Items 4 11-12-2009 12:32 AM
HSS with a non P-TTL Flash off camera? Not Registered Flashes, Lighting, and Studio 13 12-05-2007 12:12 PM
All times are GMT -7. The time now is 08:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
