Today , Played around with the R930 pair. with my 2 pentax flashes, I sudently come to an idea. How about making a powerful studio flash ?
The technics are OK already, the triggers are able to trig a pentax setting to Master wireless. who emit light and optically trig other flashes.
If I bound them together, they can become 2 Times powerful than 1 flash.
We know for HSS, the compact flash is sometimes weak outside since the sun is too bright. You have to make the flash as close as possible.
This certaintly solve the power problem.
Then I tried, Yes, they fired together in Bi-directional mode. PTTL with compensation ability.
Second, this is PTTL, How about i set the power to Manual then I can control a fix output?
I then set the R930 transmitter to Manual mode. set the power stop to 1/128. and set the flash on the receiver to Wirelss Master.
That really works. Then I set stop to 1/64,1/32,1/16 ... 1/2, 1/1, Fine!
Well, I use to consider buying a powerful studio flash. Now I only need to buy a multi flash stand.
https://detail.tmall.com/item.htm?spm=a230r.1.14.13.dyTqzc&id=528084292401&c...27b&abbucket=8
