Jun,
You already have the makings of a great kit...and you certainly will have enough to do everything you want with the pair of 360's.
I have previously shot weddings with Canon prior to moving over to Pentax last year...I have a couple of weddings coming up... In any case the Canon 580EX's worked fine for nearly all applications, and I have been playing with my K10D/540 flash for many months now and I am confident I will be able to handle the weddings with no problem.
The quantum flashes are TOP OF THE LINE....PROFESSIONAL units. BUT, I would hold off for a bit and consider this....
If you purchase a 540FGZ for about $350 and add it to your collection of 360's you will have a fantastic basis for a nice setup.
Get a couple of stands, flash adapters and umbrellas and you will take some great wedding photos.
While heavy the Al Jacobs "Black Box" is a great unit for powering the flash if you must get away from AA batteries. Check out :
MODEL ONE* STANDARD HIGH CAPACITY PACK
Al also has a smaller battery pack called the Tuxedo.
Call him or email him and I am sure he will work with you to make the adapter necessary to use in the 360/540's. He's old school, but an honest man and will work with you.
Once you have a few off camera flashes, your photos are going to take on a whole new dimension.
So, for about $600 you can get the 560 and use it to trigger your 360's or you can use the K10D's on-board wireless.
Finally, I may be wrong, but I believe you would spend well over $1000 to get a complete new Quantum flash.
Reason: additional info
