Originally posted by clackers Well, if that's what you mean, I do half agree with you.
There is a hotspot that can appear even in the final image if you don't take precaution, because the commander flash hasn't fully decayed before the shutter opens.
But your master should be pointing at the slave flash, not the subject. You can flag it (some call it the 'black foamy thing') to make sure there is no direct contribution.
A pop up flash is a little harder but you could also reflect it off a wall or ceiling with something homemade - silver foil on the back, black cloth in the front - if you really wanted to.
I want it but I don't need to, because I use triggers 930.
You can try these hard things to struggle from unwanted light. but never you can make it as easy and simple as these triggers
For example, you have many flashes at both side, which one would you point the comander to?
You can use the ugly reflect sheet. but weaken the control light, it is double edge sword.
You caon try to avoid the lit using manual mode of flash, because no metering is needed.
but hard to avoid metering confused. because this is more sensitive to weak light.
