Originally posted by kamisu Thanks for the replies. Two samples are attached. I think colors are oversaturated.
I tried to pick out things I
thought were white, and it does look like your camera may have added some extra magenta to the scene, but it's hard to tell (it could just be pink reflecting off white stuff). Why would it do this at what appears to be a little girls birthday party already overloaded with pink? Who knows! This is why I try to turn off as much automation as possible, especially when working with off brand flashes.
In the custom menu, entry 10 (it's on C2) is called "WB Adjustable Range". From the exif, it looks like you have this set to "On", which lets the camera fiddle with the WB, even though you've it set to flash. These adjustments
should be small, but I'd rather it not change it at all in case the camera outsmarts me (I don't need any help outsmarting myself), so I prefer to set this to off.
It looks like you bounced the flash off the ceiling? In this case, you don't need to set the focal length on the flash to match your camera in any way. Set it to whatever gives you the result you want - longer focal length will give a tighter beam of light and a smaller light source from whatever you bounce it off of. This can let you make a more directed light source instead of lighting up the entire ceiling. Neither way is the 'best', but both ends are worth experimenting with.
Originally posted by kamisu I tested the flash a few days ago with the attachment and photos were fine, so I do not think it was the problem.
It might not hurt to show one of these? Not to be a pain, but it's hard to judge if those toys and decorations are the right shade of pink without seeing them, so an example that you're happy with might be enlightening as well.
