Originally posted by thesia26
Some reason it didnt work and I contacted Adorama.
Are you making sure your shutter speed does not exceed 1/200s? Use "M" or "X" mode at least for testing.
Most triggers should work on a K-1 as long as you do not exceed the sync-speed.
As mikerigel wrote, if you want to use higher shutter speeds you'll have to use a V6II (or an Acon trigger may work as well), but depending on the Flashpoint trigger, you may need two V6II units as a transmitter/receiver pair, as stacking the Flashpoint trigger on a single V6II may not work.
