Originally posted by UncleVanya I'm thinking you will want to fire the cheap flash solution on manual so you can avoid having the P-TTL flashes overwhelm the sensor but your placement may make that moot. The P-TTL measured flash may be inaccurate due to the contribution of the cheapie flashes but you can probably dial those down or up as needed via flash exposure compensation.
Yep this was the goal. The cheapo thyristors would be fully manual with some way on the flash itself to dial down the power.
The idea would be to have a 4 light setup. the two AF540FGZ's up front illumination the subject with P-TTL via the ACON trigger/reciever combo, and place the thryristors behind the subject and adjust their output to properly illuminate the background, or overexpose it in the case of the white background. Something like the diagram below
----------------------------------Back Ground---------------------------------------
Thyristor ------------------------------------------------------------------ Thyristor
-----------------------------------Subject
AF540------------------------------------------------------------------------ AF540
------------------------------------- Camera
My hope is that with the Thyristors behind the subject and away from the background a significant distance the light from the thyristors should not interfere with the P-TTL function of the AF540FGZ's.....
I have seen similar set ups in photo studios used for this very purpose, i just haven't played with it yet. I am also trying to keep the cost down to under about 50 bucks, which is the reason for the desire to use old thyristors (like the vivitar 2800) and the cheap 15.00 transmitter/receiver combos from ebay such as this one
Neewer 16CH Wireless Remote FM Radio flash Speedlite Trigger w/2.5mm PC Receiver | eBay.
what is considered a reasonable trigger voltage? the neewer says its good for 12v. What flashes work with that number? Any ideas?
