I have been testing my Vivitar 2800 Thyristor off camera to see if it triggers with an optical sensor, and have discovered that it "does not". I am not going to use it on any of my Pentax dslr camera bodies to avoid voltage effects. I was using my K-5IIS to test it off camera, and supposedly the flash does not have an optical sensor. I suppose some radio triggers would trigger it, but I do not want to expose radio triggers to a possible voltage problem either. So, my conclusion is, the flash did do well on my K-1000 which I still have, but I do not want to expose my newer dslr oriented equipment to it in the interest of being safe. If anyone is curious, I bought the flash about 1989.
One more comment. I noticed also that rechargeable AA batteries fit a little bit more snug in the battery compartment, calling for a little bit more pushing the batteries down when trying to get the compartment cover on.
