Thanks for the info :
I tried with multiple lenses, all DA or FA limited .. one A50 1.7 but that worked fine.
the V6i and RF60x have more robust HSS features where banding occurs more often, so it makes sense the manual explains it more deeply.
I tried your suggestion of moving the flash on-camera, and the banding went away. So I did a factory reset on the trigger, and that seems to have solved the problem for now (it was intermittent before, so I'll have to see if it comes back in a few days).
One thing I noticed is in M mode on my K5, the shutter speed jumps from 160 to 200 directly. I looked at the menu settings .. EV is set to 1/3rd of a stop, ISO set to follow EV sensitivity.... is there a shutter range menu item I missed? ... I can't seem to get it to hit 180 ( i have f-stop on the rear dial, shutter speed on the front dial ... does each dial have finer/coarser gains?)
Always much to learn. Thank you guys!
