Originally posted by ruslanvremea Hi everyone!
Recently I discover what my pair of Metz 58af-1 and K-3 does not work as good as earlier ((
1) In PTTL-mode, the flash symbol disappear sometimes from viewfinder and didn't fire. This can be fixed just by shaking of the flash and camera.
2) In A-mode the flash can't read at all the camera settings and fire only at full power.
In M-mode the flash works perfectly.
Wait for your suggestions. Thanks
I have the same flash and the same problems from time to time. It's just oxidation of the contacts. If you're out in the field and it happens, just remove the flash and then remount two or three times. That usually does the trick by scraping away some of the oxidants. Basically, this is not a problem specific to that flash unit or camera. I have faced this even during my film days and is down to having a heavy flash and the stresses imposed on the camera hotshoe.
Cheers
