Originally posted by artripoli I have a k100d and an AF540fgz flash. I want to use my pop-up flash to trigger my 540fgz off camera. Is this possible?
To my knowledge, the K100D doesn't support P-TTL wireless with the on board flash. SL1 mode is not available.
You can however use the optical slave, SL2, mode. Still no wires, but no communication between the camera and flash for setting up the flash. You set the 540fgz manually and use the on board flash just to trigger the 540fgz.
You can find the 540fgz manual
here in pdf from.
Thank you
Russell
