03-17-2017, 04:17 AM   #1
eccs19's Avatar
Question regarding older studio strobes
I recently picked up an older Speedotron lighting setup. It came with the cable to hook into the PC Sync port on my K-1. I know there are known high voltage issues with speed lights that go into the hot shoe. Do I need to worry about this potential issue using pc sync? The power pack in question is a Blackline model 2403B if that makes a difference.
I guess the next question would be, if the voltage will be an issue, what's the best way to tackle / isolate the setup from the camera to prevent damage?
03-17-2017, 05:48 AM   #2
UncleVanya's Avatar
My understanding is that the PC port is designed to be exposed to higher voltage. However the lack of reliable data on the limitations of this makes the risk of damage a concern. I personally would use a safe sync port like the one described in this article:
Trigger Voltage Limits with Modern Digital Cameras - Steve's Digicams Forums
flash, issue, lighting, pc, photo studio, question, setup, strobist, sync, voltage
Using a Grey Card and Studio Strobes with K-1 dcpropilot Pentax K-1 11 01-14-2017 04:20 AM
K-1 Unusable at 1/200 using Studio Strobes??? dcpropilot Pentax K-1 29 08-16-2016 03:07 PM
Question regarding older Pentax lenses on K1 CDW Pentax SLR Lens Discussion 9 06-24-2016 01:29 PM
645z w/ Studio Strobes orbitalpunk Pentax Medium Format 6 12-29-2015 11:53 PM
studio strobes and hs flashes question piskota Flashes, Lighting, and Studio 9 09-01-2011 01:30 PM
All times are GMT -7. The time now is 07:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
