Show Printable Version 11 Likes Search this Thread
04-24-2017, 04:55 PM   #16
Thanks for the suggestion, but unfortunately the metz 48 af-1 only supports slave mode for p-ttl , it cannot control other flashes. What I do for avoid wasting too much battery is to put -3EV compensation on the flash.
04-24-2017, 11:57 PM   #17
mcgregni's Avatar
That's a good approach considering that limitation, and probably doesn't spill any significant light into the scene.
06-15-2017, 05:43 AM   #18
Culture's Avatar
If I wanted to get the AD200 which of the transmitter versions do I use. X1T-N or X1T-C.
I will mount it on my Cactus V6II which is universal but does it which you choose?
06-16-2017, 04:43 AM   #19
I don't think it matters too much. I am using the X1T-C for mine. I think the general consensus has been that with Nikon you might get the wake function to work with them whereas that will not work for the Canon version.
07-03-2017, 02:35 PM   #20
QuoteOriginally posted by jake14mw Quote
This is a very interesting info. So, is HSS working for you, with the V6 II + X1T-C & AD200's wireless mode ?
To get HSS, I have to put a FT16R or XT16R receiver on my AD200, and disable the wireless mode.
Also, I have read on other forums that the X1T canon version have several bugs with the XTR16 receivers, when want to disable a device with such receivers.
Regards.
07-18-2017, 12:00 PM   #21
DimC's Avatar
Hi all,
I will rent one for a wedding im shooting mid august. Is there a Pentax version or is it only generic ?
I intend to use it with my Godox XT16 transmitter, for off camera flash (on my K1).
Any tips appreciated, thanks !
07-18-2017, 10:47 PM   #22
Culture's Avatar
QuoteOriginally posted by DimC Quote
Hi all,
You mean the AD200? Yes its generic. Pentax does not have its version.
I have not done my research in full, but I think the XT16 should work with it. The AD200 has a built in receiver.
What you will need though is maybe a Cactus V6II between the camera and the XT16.
Between. I checked your site. Really nice work. I noticed you shot a lot of africans. So I checked you out.
I see you lived in Ivory Coast. I am from Ghana myself.
It will be nice to see your wedding shoots when they are done.
Culture.
07-19-2017, 03:46 AM   #23
DimC's Avatar
QuoteOriginally posted by Culture Quote
Culture.
Hey thanks for your advice Culture, why do you think i should get an Cactus V6 II ? for HSS ?
I now live in Paris, France. Used to live in Abidjan for years, I love Ivory Coast man and I miss my people a lot.
Where are you based ? I was the only one photographer shooting Pentax while I lived in Abidjan, and I was very often the only one able to shoot in difficult weather (super hot and humid outside, air conditionning inside), Pentax K20D by that time !
Wonderful weddings shots on your gallery ! congrats!
07-19-2017, 10:42 AM   #24
Hi all,
Hello, I can confirm that you can control and fire the AD200 by:
* using the 433Mhz FT16 and putting a FTR16 receiver on the AD200's USB port, and disabling the wireless mode
* using the XT16 or XT32-C and enabling the wireless mode. Also you could put a XTR16 receiver on the USB port and disable the wireless mode
Just put your FT16/XT16/XT32 on top your camera's hotshoe, a receiver (if needed) on the USB port, adjust the channel and group, and you are done.
Only if you want HSS, that is, to fire above 1/180, then yes, you need a V6II.
I used mine on First Communions this year and I'm quite happy with it.
Salutations.
07-19-2017, 01:40 PM   #25
DimC's Avatar
QuoteOriginally posted by morenjavi Quote
Salutations.
Thanks a lot for this information, Ill report back to you.
07-19-2017, 10:07 PM - 1 Like   #26
Culture's Avatar
I see the question has been answered. Yes I meant HSS. I suspected that as a wedding photographer you might at times need to use HSS.
I am now based in Finland. If I had the opportunity to have quarter of my gear with me when I visit home. I would have a fun time.
Culture.
07-25-2017, 01:19 PM   #27
Salutations.
I have the cactus 6vII, x1tc and AD200 with a 645Z. It will not work in HSS or over 1/125. SO from what I am reading if I use the cactus and the XT16 system I will be able to shoot above 1/125. has anyone verifyied this?
I am currently using a Profoto B1 with the Cactus on the 645 with good resoults in HSS. just would like a lighter light. Thanks in advance
07-25-2017, 02:14 PM   #28
DimC's Avatar
I'll be able to tell you by the end of the week.
I'm using a K1 as a difference.
07-25-2017, 04:09 PM - 1 Like   #29
QuoteOriginally posted by Kmaphotog Quote
Hello, I can tell you what worked for me. I tested wit with K5 & K3II. You have a 645 and it seems your Cactus v6II is able to get the HSS signal.
To get HSS with the AD200 & V6II you can check the next combinations:
* put a general trigger on top of your cactus v6ii, and the corresponding receiver connected to the AD200's sync port. Disable wireless mode and enable HSS on the AD200. HSS should work.
* put a FT16 on top of your cactus, then put a FTR16 on the AD200's usb port, disable wireless mode and enable HSS.
* put a XT16/XT32 on top of your cactus, and (important), a XTr16 receiver on the usb port, disable wireless mode and enable HSS. It should work with your X1Tc too, but I coulnd't test it
The problem is that HSS doesn't work if you use the wireless mode and the AD200's internal receiver. I know, it doesn't make sense but...
I hope this info be useful.
Regards.
Forget to add: on the cactus v6II, I configure the flash as manual, and HSS as 'powersync'.
07-25-2017, 07:48 PM   #30
Class A's Avatar
Yet another option that should work is to not add any trigger to the on-camera V6II, but connect another V6II or a V6 to the AD200 via a sync cable. On the AD200, disable wireless mode and manually engage HSS.
That might be a good solution for anyone who happens to have more than one V6II unit or has additional V6 units available. It is not a very cost-effective solution for anyone not having these units anyhow.
645z, ad200, cactus, flash, godox, hands, hotshoe, hss, lighting, photo studio, port, post, power, receiver, settings, setup, strobist, sync, v6ii
Getting Better Flash Bursts: Godox li-ion vrs external battery pack Doundounba Flashes, Lighting, and Studio 107 10-01-2018 02:30 AM
Anyone using the Godox V850? jbsg02 Flashes, Lighting, and Studio 77 03-19-2016 01:15 AM
For Sale - Sold: (Flashes Pentax AF 360FGZ II) SOLD and Godox Ving V850 GN58 (manual flash) MINT cake Sold Items 5 02-18-2016 11:25 AM
Not Work-Safe Test Shots with Godox V850 bogdan01 Post Your Photos! 11 12-24-2015 04:32 PM
My Review of the Godox AD360 pursang Flashes, Lighting, and Studio 4 05-25-2015 06:59 PM
All times are GMT -7. The time now is 12:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
