---------- Post added 05-31-18 at 12:39 PM ---------- Originally posted by T Evergreen To use the 585 off-camera in P-TTL mode, you need a master/controller on camera like the 540 or 360 as was mentioned earlier. You can use the 585 off-camera in manual mode by triggering it with the built-in flash. This requires you to set the 585 in S1 or S2 mode as appropriate. You access these two slave modes by a long press of the "Mode" button on the 585 and then using its four-way controller to step through through the various options. See page 10 of the 585 manual.
Thanks. I was able to find the instructions on page 10 and 14 of the manual. it can be fired off camera on S1 with your on camera flash operational. Works as a slave. Thanks everybody for helping me through this.
