I was using F 501.7 and DFA 28-105. Both of them I set on ISO 100, TV at 180. Distance, I may have it really close to the subject, less than 4 feet. I used both with and without flash compensation. I tried bounced and direct. The range indicator works, and the zoom responded with the zoom on my DFA 28-105. At first it fired, underexposing, when the red indicator illuminated. Now it illuminate, but does not fire.
Originally posted by mcgregni
Could you also tell us what lens you were using for the P-TTL mode shots, plus the ISO, aperture, and distance to subject.
And was any flash compensation set on either camera or flash?
Are you referring to direct or bounced flash?
Did you see the range indication before taking shots, and was your subject within this? Finally, did the 'flash ready' red indicator illuminate before taking each shot?
All of this extra info will help to diagnose the likely problem.
---------- Post added 04-10-2017 at 11:44 AM ----------
Originally posted by UncleVanya
When the flash is of camera does test work? I had an af540fgz go bad on me. One day perfect, a few weeks later I went to use it and it was totally dead. I did the same "batteries must be bad..." thing also. In the end I sold it for parts.
When I turned it on, after the test button illuminates, it would fire one time. Afterwards, button illuninated, but could not fire. This is when I start to have that sinking feel, but I still have a hunch that some big user error is behind this.
