Originally posted by Culture The triggers came with V1.1.006. And I read somewhere that that was the most stable version. So I have not updated it.
Good.
I think even V1.1.009 isn't as good as V1.1.006 was (as far as Pentax is concerned). Hopefully, they'll keep working on getting Pentax support back at 100%.
Originally posted by Culture I removed the Yongnuo triggers and mounted the flash directly to the Cactus. I figured it should be able to trigger the YN560II. Still banding using power sync mode.
By "banding" do you mean a black bar?
Some gradation is to be expected when using Power Sync. Only when using HSS (with an HSS-capable flash) you should expect an even exposure across the frame.
Have you tried setting the flash system on the on-camera V6II to "Nikon"?
I've read that this is the best setting for the trigger stacking approach.
Originally posted by Culture What is this manual flash option in the flash setup. Will the RF60 be that manual flash being talked about?
The RF60 does not require any configuration.
The "MANUAL" flash option is for flashes that are not system-dedicated, i.e., that work by centre pin triggering.
Normally, the "MANUAL" setting should also be the best choice for your trigger stacking application. For some reason (read "a bug"), however, choosing "Nikon" as the flash system is the better choice.
BTW, for Power Sync you can change the trigger timing. Press the dial and turn it at the same time while you are in the Power Sync menu option. This timing flexibility can help you to remove black bars. However, if the bar is at the bottom (and you are not using a K-1) then I don't think you'll be able to improve matters as the default timing should be "as fast as possible" and a black bar at the bottom means "too slow".
It is possible that the Yongnuo triggers are too slow. There are models that require communication with a camera to be as fast as they can. Otherwise, they'll introduce some lag (which will manifest itself as a black bar at the bottom).
