04-12-2017, 03:40 PM - 2 Likes   #1
Starting to test Godox HSS with Cactus V6ii, HSS works in AV mode?
Hi all,
I am starting to test my fairly new Godox system in HSS mode using a Cactus V6ii on my K-5sii. It was my understanding that HSS would not work with the Camera in AV mode. In the tests that I just did, it seems to work fine in AV mode. I tried in both AV and M, and seems to work either way. I was under the impression from any reading that I had done that if the camera was in AV mode that the flash would not fire with a shutter speed faster than 1/180th. I thought I would have to use M mode. Maybe just PTTL HSS won't work in AV mode?
This was using either a Godox AD360, or a Godox V850ii.
04-12-2017, 07:46 PM   #2
clackers's Avatar
Well, that's right, Jake, you're not using P-TTL, you're firing a Godox HSS in Manual mode with a third party trigger in between, right?
04-12-2017, 09:43 PM   #3
Yes, Cactus V6ii in the K-5iis hotshoe, the Godox X-1T transmitter on top of that triggering the Godox flashes.
04-12-2017, 10:18 PM   #4
clackers's Avatar
QuoteOriginally posted by jake14mw Quote
Yeah, I've ordered the AD360 II, XT16, Cactus V6ii combo.
04-13-2017, 01:02 AM   #5
mcgregni's Avatar
I am surprised by this, because my assumption has been that the V6II appears to the camera to be a P-TTL HSS flash, and so I expected the behaviour to be the same.
I know Av mode is favoured by some flash photographers, so it's good to know it's there with this configuration if wanted .... Are you saying you get good, stable, reliable ambient exposures then? Can you control it precisely and consistently with exposure compensations? What shutter speeds is your camera choosing, and do they remain fixed and stable for the duration of the session?
04-13-2017, 06:21 AM   #6
QuoteOriginally posted by mcgregni Quote
I was also very surprised, I thought the same thing. Yes, I was getting good consistent ambient exposures, didn't try exposure compensation. It was just a quick test session. The camera chose all different SS based on the ambient, up to 1/4000.
04-13-2017, 07:30 AM   #7
mcgregni's Avatar
It wouldn't be much use unless you could take firm control of the ambient exposure with compensation, so it would be great if you could test this. It it was dependable then it adds to the control options available, so a plus for sure ....
av, cactus, camera, flash, godox, hss, hss with cactus, lighting, mode, photo studio, strobist, test, test godox hss, v6ii
Pentax HSS with Cactus V6ii and Godox Ving 850 Flash - Success howieb101 Flashes, Lighting, and Studio 46 09-02-2018 09:00 AM
Pentax HSS with Cactus V6ii and Godox Witstro AD360 Flash Light Speedlite fwbigd Flashes, Lighting, and Studio 89 04-23-2017 07:37 PM
Cactus V6ii Firmware Update 1.1.07 and 1.1.0.8 Problems-With HSS on Godox AD360 fwbigd Flashes, Lighting, and Studio 6 04-11-2017 04:57 AM
HSS With Pentax K-1+Cactus V6ii and Godox 360 fwbigd Pentax K-1 19 03-10-2017 08:55 AM
Used Cactus V6II and it works Ken Pimontel Flashes, Lighting, and Studio 11 08-27-2016 05:00 AM
All times are GMT -7. The time now is 03:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
