04-15-2017, 07:11 PM   #1
lightbox's Avatar
AF-540FGZ II sporadic misfires on K-50
Hi all,
I recently picked up a 540FGZ II in order to have a TTL bounce flash that works with my Pentax. Happy to report that P-TTL works great, but I noticed that the flash sometimes fails to fire when triggered from the hotshoe. The flash feels a little loose when mounted on my K-50, even when the clamp is in the "lock" position. I confirmed the same on a K-S1 which I recently purchased for my wife (however haven't had enough time to test for misfires on that camera).
I think the misfiring is dependent on the position of the camera. I was test shooting a wine bottle in the kitchen and when the camera was tilted slightly downward it would misfire. Leveling the camera seemed to resolve the misfires, though more testing is needed.
I was wondering if this is a known issue with Pentax gear. Are the hotshoes just loose by design? The only other brand I have experience with is Nikon (an old D80) and did not have this problem using the SB-800 flashes.
Appreciate your feedback!
04-16-2017, 02:51 AM   #2
No, it is not normal for the hotshoe to be loose. It does sound like that could be the source of the problem.
I did have similar misfires with a Metz flash on K-50, but that was resolved with a firmare update and isn't relevant to your problem I don't think.
04-17-2017, 06:36 AM   #3
lightbox's Avatar
Thanks for the reply.
I did notice one misfire yesterday as I was using the flash on my wife's K-S1. However the camera was on a tripod and level. I need to spend more time with this.
Has anyone else with an FGZ540 II experienced misfires?
04-18-2017, 05:43 PM   #4
QuoteOriginally posted by lightbox Quote
Hi all,
I had the same problem with the previous model, there is a little contact that comes down when the base is tightened, something wore and it didn't come down any more and the flash would not tighten against the shoe. I had the base replaced for $200.00
Tuggie76
04-19-2017, 03:01 PM   #5
lightbox's Avatar
Thanks, tuggie & Brooke.
I think I'm not going to sink any more money into it, so will just work around the issue since it's intermittent. It's probably the flash as two separate cameras (one new, one never used with a hotshoe flash previously) is too much coincidence.
I used it over the weekend to bounce off the ceiling for some foreground fill in family / group photos. When it worked, it worked well. Just a few misfires, so fortunately a minor inconvenience.
04-19-2017, 03:08 PM   #6
lightbox's Avatar
If anybody knows of a cheap (< $50) fix, I'm all ears.
If the suggestion is a hotshoe cable, then I might as well hold the flash with my other hand and trigger optically. But I'm looking to keep this flash fixed to the camera (I've got others with radio triggers for off-camera, manual exposure). Just wanted at least one P-TTL unit for bounce/fill on camera.
04-19-2017, 03:46 PM   #7
Theov39's Avatar
If new, why not return it under warranty? That is the latest model so you shouldn't have to put up with that inconvenience. Sounds like the center pin is not making firm enough contact.
On Nikon flashes you can replace just the hot shoe part for $20 or so for the part (the hot shoe is just held on with 4 small screws so you it's a DIY job) but not sure if that is possible on Pentax flashes.
04-19-2017, 04:14 PM   #8
lightbox's Avatar
It's not new
QuoteOriginally posted by Theov39:
Something like that would be fantastic
04-19-2017, 05:49 PM   #9
Theov39's Avatar
Would a drop of solder on the end of the pin do the trick? Perhaps very carefully pressing in the hot shoe holder on the camera a fraction to get a tighter grip?
I only have the AF200FG and that seems non-serviceable to me but of course the 540 is a completely different design so there may be some more options for a cheap repair.
Yes, the Nikon solution is very smart. They count on the fact that the hot shoe connection/foot on the flash can break or mis-function now and then so just that part is designed to be easily replaceable without having to get rid of the whole flash.
af-540fgz ii, camera, flash, ii, ii sporadic misfires, k-50, lighting, pentax, photo studio, position, strobist, test
Flash: AF-360FGZ II vs. AF-540FGZ (original) slowdive101 Flashes, Lighting, and Studio 11 02-24-2018 03:25 AM
AF-540FGZII Misfires Mikesul Troubleshooting and Beginner Help 5 08-06-2015 05:48 PM
AF 540FGZ and AF 540FGZ ii size comparison? Trey45 Flashes, Lighting, and Studio 13 02-14-2015 02:52 PM
Cactus V6 misfires on Pentax ME nono Flashes, Lighting, and Studio 12 01-03-2015 03:25 PM
All times are GMT -7. The time now is 06:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
