Originally posted by Andrzej Makuch Electrical problems? I do not know ? Rather electronic.
No, "electrical". But feel free to draw your own conclusions.
Also, it is difficult to help you troubleshoot things when you don't reply to questions.
I asked you twice now whether you tried another unit as the transmitter unit (in the other thread).
Originally posted by Andrzej Makuch Do your V6II always show version 1.1.006? Even after the last update?
I haven't tried updating to V1.1.009 yet.
If the version number does not change after an update than you are forgetting to press the "Check for latest firmware" button before pressing "Update". The latter button just transfers the currently selected firmware to the V6II unit. In order to get the latest firmware version, you have to press the other button first and then select the one you want from the list.
As I said before, I don't think a change of firmware will address your specific problems. You should try to change the unit and/or perform the
trouble-shootings steps I suggested. Good luck.
