Originally posted by gutter rock Okay I generally hate flash but really want to try a ring flash for portraits to get that 90's style fashion look! Is the AF080C powerful enough for portraiture? The guide number is only 8 I believe although I am a bit confused by these ratings. It seems people only use this for macro work so googling has been a lost cause.
I have this flash and can give advice. Short version: it's a short range macro flash for cameras with full analogue TTL protocol. Stay away from it otherwise - it's good for what it was designed to do, but IMO that isn't portrait work.
Do you have the flash now, or are you only thinking about getting one? The mounting ring is designed to go on a lens with a 49mm filter ring - putting step-down rings on a lens with a much larger front element (particularly a DA lens) might cause vignetting, depending on your lens and your camera (full frame vs APSC).
If you're going to use an AF080C, you really need a camera that supports TTL protocol - and in digital that means *istD, *istDS or *istDS2 - 13 years old and 6MP crop cameras. Otherwise you will probably find yourself constantly having to guess the right setting and retaking a lot of pictures. I have one, and at close range I am constantly dialling my K-5's ISO down to 80 and closing the lens all the way down, even at quarter power. Don't expect to be able to use your ultra-fast portrait lens wide open with any ease, unless you're using a flash-compatible exposure meter and your camera/lens/flash unit is on a tripod.
