Originally posted by Class A Have you tried to go back to V1.1.004?
Have you tried a factory reset?
It seems unlikely to me that you are facing a hardware issue, so I'm sceptical that replacing the unit will change matters.
What trigger are you trying to use on top of the V6II?
Given that things initially worked, you should be able go get there again, with just the right configuration. A factory reset and a stepwise attempt at reproducing your initial configuration should get you there.
So here am I again.
I did a reset (in my case goes back to 007 firmware)
camera system: pentax
flash system: canon
flash profile: auto canon
trigger above cactus: air remote ttl-c (canon)
After that had different results: a.) could fire HSS but not the 1st curtain (in case you dont know, there are three options to be set on the trigger:1st,2nd,hss)
2nd curtain never worked for me anyway.
then, turned everything off, had some lunch and came back to retry b.) could fire only the 1st curtain but no HSS this moment the batteries on the profoto trigger was almost empty. recharged the battery and c.) could fire hss in manual mode and 1st curtain only in TTL (even if it doesn't read ttl).
When changing between HSS and 1st in Manual mode I noticed that the shutter speed value in the camera changes. The options between 60th and 160th of a second do not show up, only when i change to TTL.
So that's where I am, downgraded to the 006 firmware and the results are the same.
HSS in manual mode and if I want to use the pentax sync speed or lower have to go TTL
