06-02-2017, 04:50 PM   #1
Saltwater Images's Avatar
Flash modifiers - anyone try the Lastolite Ezybox Speedlight 2.
I have a collection of larger modifiers, mostly umbrellas (silver, white and shoot-through) but also Sto-Fens (white, orange and blue). I'd like to add a small modifier to my kit that can be used on and off camera - indoors and outdoors. Tried the Flashbender and the Fong Dong and wasn't impressed with either. The Fong is heavy and only works well inside when you have walls and a ceiling to bounce light off of. The Flashbender was ok but didn't give me much more than a home made black & white foaming thing (aka BWFT). The BWFT is made by sticking two sheets of 8.5" x 11" craft foam together and attaching it to the flash with a Velcro strap. One side acts as as large bounce card the other for shaping light direction. A BWFT only costs $3 to make and the Flashbender costs a lot more.
I'm Considering the small Lastolite Speedlight 2 soft box for indoor and outdoor events. Has anyone tried this mod for inside and outside portraits? What are your thoughts?
06-03-2017, 03:17 AM   #2
Hi:
I have two Lastolite Ezyboxes--with both I use my Metz speedlites. One is 24x24 and the other is 8x8 (I think 8.6x8.6). I also own the Hilite 6x7 background.
Lastolite is a very good brand and value. A touch expensive, but I have owned the Ezyboxes and Hilite for several years and they have stood up very well. The Hilite is great to work with. I take pictures as a hobby. So, I do not put my equipment through harsh use, but all my gear still takes the typical use, bangs, and knocks as most others, though, I do my best to treat everything as carefully as I can.
I really like the Ezyboxes. They set up well, quickly, and are easy to use. There is of course a limit as to how soft the light can get with a very small softbox, but I really like using the Ezyboxes and are they very worthwhile. They set up easily and store flat in a really nice case. The smaller one easily fits in a front pocket of my Lowe Pro bag (it's a large backpack). The 24x24 is too big for a backpack, but stores and travels very easily.
Over the years we all accumulate "stuff," but i consider the Ezyboxes, and especially the Hilite, as some of my best purchases.
I typically have used the smaller Ezybox for indoor portraits, triggered with a CyberCync. I place the smaller Ezybox on the end of a small light stand or extension arm which I hold by hand and use my other hand to shoot. I have shot musicians in bars and nightclubs with the smaller Ezybox. I have found this is much less intrusive and bothersome than a bare flash. I used to think flash would not be permitted, but I am pretty quick with shooting and the local musicians have really liked the images. For the 24x24 I use a small light stand and take it with me when I want a softbox on location and do not want to bring larger lighting gear and a portable power supply.
Any other questions, let me know.
Good luck.
06-03-2017, 12:06 PM   #3
I am quite pleased with the Lumiquest ProMax Ultrasoft diffuser, which is held onto an upward-pointing head with velcro. It's very quick to put on and take off and folds down compactly to fairly flat, fits in front pocket of my bag.
06-03-2017, 03:16 PM   #4
QuoteOriginally posted by candgpics Quote
Hi:
Good luck.
Thanks. I picked up the Lastolite Ezybox Speedlight 2 this afternoon and will use it with a Cactus RF60 flash and V6 Radio Trigger. I took a handgrip from a Rotolight Kit and attached a cold shoe to mount the flash and small Ezybox. Will try it hand-held as you do and my have my amazing wife hold it as a voice activated human light stand (more maneuverable than my Manfrotto light stands):-)
The Ezybox is a great piece of well built kit. The dial to lock the Ezybox 2 onto the flash is the best mechanism I have seen for a simple and solid mount.
06-04-2017, 02:14 PM   #5
Sounds good. I think you will like it. Very well built and portable.
06-05-2017, 10:20 AM - 1 Like   #6
I would stick with the Foamie. It's all about the size of the light source. The foamie will give you the same size as the Lastolite. I tested a ton of things DIY and otherwise. It's just strictly size and ease of use. There is no magic modifier for on camera flash.
flash, flash modifiers, lastolite, lighting, modifiers, photo studio, strobist
Considering light modifiers for my light modifiers lithedreamer Flashes, Lighting, and Studio 6 12-27-2016 02:48 AM
Light Modifiers abuddhazaki Flashes, Lighting, and Studio 2 02-11-2016 06:20 PM
Softbox recommendation: EZYBOX, OctoDome3, neither? MrPetkus Pentax Camera and Field Accessories 6 04-24-2010 07:45 AM
All times are GMT -7. The time now is 03:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
