Originally posted by BrianR t.1 of the 540fgz at full power was measured to be 1/200th (by forum member AstroDave, yay!).
Sure, but note T.1 means there is still another 10% of light to come.
BTW, I quoted from the Metz 58 AF-2 manual and also once confirmed through measurements that you can increase the exposure you can get from a full power flash by not using the speed sync (1/180s for most Pentax DSLRS), but by going a bit lower. At 1/125s there was a measurable increase in brightness compared to 1/180s. Perhaps a good tip for anyone trying to squeeze the most out of their flash.
Originally posted by BrianR For the applications Bruce has mentioned, this is mostly fine.
Sure. I wasn't commenting on Bruce's applications.
I was responding to mcgregni's comments about HSS. I don't entirely disagree with him, but one should be aware of the fact that unless one chooses a low enough output level, flash exposures are all but "instantaneous". That's all.
